With interest in using an electromagnet to lift up a magnet.
I dove in. I will state general information. The set up is unknown but I'm interested in the physics/electrical engineering involved in calculating the amount of ______ needed to lift up a mass (magnet with magnetic strength x).
I reviewed "electromagnets". I see an inductor produces a magnetic field, a summation of the contributions of electrons and we get some equations.
Regarding inductors, Energy is .5LI². We can adjust the power/energy/magnetic flux in an inductor by varying the voltage/current/turns, etc.
Also since V = dϕ/dt, maybe we can integrate velocity to find the magnetic flux or something but idk if magnetic flux is relevant to lifting a magnet on the ground.
So I found a link to the an equation expressing the force between two magnets in Newtons homework and exercises - calculate force between two magnets - Physics Stack Exchange
I see magnetic force is measured in Gauss.
I've nearly finished relearning Classical Mechanics, so I'm thinking about using F = ma, and I'm not sure how the inductor/"electromagnet" ties into this nicely.
I don't know how to convert an inductors properties into Gauss, nor express it as a function of distance, and I think you guys can help!
I considered using F = kqq/R or some other attraction law, but still idk how to relate an inductor and it's Joules or other properties to "magnetic strength" I can use in a kinematics analysis.
