I think this might actually be quite simple but I can't find info on it anywhere and I can't think how I would do it. I want to split an 8 bit BCD into two 4 bit BCDs so for example if I get an input of:
01011100 I want two separate outputs of 0101 and 1100.
Similarly how could I then split the 0101 into 4 outputs of 0, 1, 0, 1 and the same for the 1100 into 1, 1, 0, 0?
  • \$\begingroup\$ It's just a lane change. I don't see the complexity here. Is there something I'm missing? \$\endgroup\$
    – jonk
    Feb 3, 2021 at 13:41
  • \$\begingroup\$ This takes no hardware whatsoever. \$\endgroup\$
    – user16324
    Feb 3, 2021 at 14:20
In VHDL, you can directly slice the array. Let's assume allparts is the 8 bit BCD array you want to slice, and first_part and second_part are the 4 bit BCD signals you need.
allparts, first_parts and second_parts is of type std_logic_vector.
firstpart <= allparts(7 downto 4);
secondpart <= allparts(3 downto 0);
...or if firstpart and secondpart are simply alternate ways to refer to part of the allparts signal, you may want to use an alias:
alias firstpart is allparts(7 downto 4);
alias secondpart is allparts(3 downto 0);
Credits: Charles Steinkuehler https://stackoverflow.com/a/10376420/12311164
  • \$\begingroup\$ Is there a logic gate way as well? \$\endgroup\$
    – Matt
    Feb 3, 2021 at 13:43
  • \$\begingroup\$ @Matt you don't need a logic gate here since you don't have a function for the logic gate to perform. You can either directly connect 4 bits as a separate signal or use a buffer. \$\endgroup\$ Feb 3, 2021 at 13:59
