I'm trying to solve a practice problem, which is represented by the schematic below.
We are asked to relate the voltages \$V_1,V_2\$ to the output voltage \$V_o\$. The value of R is considered to be known, and all transistor base voltages are considered zero. The input voltages aren't specified as DC or AC, but previous problems from the set considered them AC. The base-emitter bias voltages are considered to be \$Vbe = 0.7 V\$.
My steps to solve the problem:
- The left part of the circuit is a buffered current mirror. This means that the current across the leftmost resistor 2R is reflected across the rightmost resistor R.
- The current across the leftmost resistor is \$I_c = \frac{V_1-1.4}{2R}\$. This current is reflected to the rightmost one, R
- We can calculate the voltage drop across R to find the collector voltage of Q2.
\$V_C2 = Vce_2 = Vcc - I_cR = Vcc - \frac{V_1-1.4}{2} \$
If my calculations are correct, this is the input at the non-inverting terminal of the opamp. And this is the point where I can't determine the operation of the opamp, and am conflicted. I've seen how the most common configurations are wired, but none of them feature this topology. Textbook inverting configurations require the non-inverting input to be grounded. Inverting configs require the inverting input to feature feedback, but it's input is grounded. Differential amplifiers have another resistor after 0.5R to ground.
I also understand that, ideally, the voltage at the input terminal should be the same as the output of the mirror, since no current flows in or out the terminals (in an ideal amp) and there's a virtual ground between the two terminals.
Any pointers on how to decipher this are appreciated.
