I'm using a raspberry pi to program an atmega328p. During my tests I was using 3.3V to power the avr and it was pretty straightforward, whenever a program is about to be written I pulled low pin 1 (reset) as per the specification and went to town.
Now the real deal is running on 5V and thus it's pin 1 is also kept high with 5V.
Pretty much anywhere you look you will find that feeding 5V into a GPIO is not a good idea, however with a 10k resistor that's about 0.5mA which should not be a problem?
Alternatively if I had to use a transistor, I'm guessing I'd have to go with a PNP type which would also sink the 5V so I don't really know how that would work out.
I'm still just a noob here, please don't be harsh, and thank you for your time!
No, this is outside of the pi's electrical specs.
Use an NPN transistor (with base resistor) or better and more simply N-FET, either configured as an inverting "low side switch" to pull down the ATmega's reset line, in response to a positive output from the PI GPIO.
Also make sure you're performing appropriate level conversion on any UART or other signals between the pi and ATmega.
  • \$\begingroup\$ But how would I go about if I use the default avrdude configuration in which the reset pin geta pulled low. That wouldn't work with an npn transistor and a pnp would still have to sink more than 3.3V? \$\endgroup\$ – php_nub_qq Feb 4 at 17:44
    \$\begingroup\$ Change the software, perhaps adding an "invert reset" as a commandline/config file option, done right it's probably worth a pull request (assuming avrdude actually knows about linux GPIO's and isn't just using a helper program). Or if you're unwilling to do that, put in an inverter (IC or another transistor) between the GPIO and the transistor, or use a non-inverting buffer with suitable specs to output 5v logic while accepting 3v3 logic. \$\endgroup\$ – Chris Stratton Feb 4 at 18:59
  • \$\begingroup\$ I've got some of those cheap 3 to 5 volt logic level converters but I'm not sure how that would work with pulling the high side low... \$\endgroup\$ – php_nub_qq Feb 4 at 19:19
  • \$\begingroup\$ The ones with the FET in the middle and the pull-up resistor on each side would probably work if you get the high/low voltage sides properly oriented, since for the reset line you're basically doing what they do which is switching low or letting a pull-up hold it high. At moderate baud rates (and/or adding lower value pull-ups) the other channels would also work for serial UART. \$\endgroup\$ – Chris Stratton Feb 4 at 20:15
No, the Raspberry Pi IO pins are NOT 5V tolerant. Limit the input to 3.3V.
There are many ways to do this, but the easiest way would be using a 74HCT14 and chaining two for the proper logic. I would use the 5V rail in the Pi for this to power it. I would also put a 100 ohm resistor in series from the Pi's GPIO pin to the 74HCT14 just for protection in case the 74HCT14 fails.
