I am new to electronics. I am trying to figure out voltage divider to bias a transistor in saturation mode to drive a relay coil. Here's the circuit:
The coil resistance is 270 Ω. So the collector current has to be 44 mA. With hfe = 110, Ib = 0.4 mA. So R2 = 12V / 0.4 mA = 30 kΩ. Vb has to be lower than Ve by 0.7V. Let's say 11V. So R1 = 3.3 kΩ. Am I correct so far?
Also in some tutorial it says "The amount of biasing current flowing through resistor R2 is generally set to 10 times the value of the required base current IB so that it is sufficiently high enough to have no effect on the voltage divider current or changes in Beta." What does that mean exactly?
