The clk signal is not being provided to the device under test from the test bench. I am unable to find the issue. It simply outputs 'U'.
What could be the issue?
The current output
Testbench for counterEx
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity counterEx_tb is
end counterEx_tb;
architecture arch of counterEx_tb is
constant M : integer := 10;
constant N : integer := 4;
constant T : time := 20 ns;
signal clk, reset : std_logic; -- input
begin
unit : entity work.counterEx
generic map (M => M, N => N)
port map (clk=>clk, reset=>reset);
-- continuous clock
process
begin
clk <= '0';
wait for T/2;
clk <= '1';
wait for T/2;
end process;
-- reset = 1 for first clock cycle and then 0
reset <= '1', '0' after T/2;
end arch;
counterEx (device under test code)
library ieee;
entity counterEx is
generic(
M : natural := 6;
N : natural := 4 -- N bits are required for M
port(
clk, reset : in std_logic
end entity;
architecture arch of counterEx is
type stateType_moore is (start_moore, count_moore);
signal state_moore_reg, state_moore_next : stateType_moore;
signal count_moore_reg, count_moore_next : unsigned(N-1 downto 0);
begin
process(clk, reset)
begin
if reset = '1' then
state_moore_reg <= start_moore;
count_moore_reg <= (others => '0');
elsif rising_edge(clk) then
state_moore_reg <= state_moore_next;
count_moore_reg <= count_moore_next;
end if;
end process;
process(count_moore_reg, state_moore_reg)
begin
case state_moore_reg is
when start_moore =>
count_moore_next <= (others => '0');
state_moore_next <= count_moore;
when count_moore =>
count_moore_next <= count_moore_reg + 1;
if (count_moore_reg + 1) = M - 1 then
state_moore_next <= start_moore;
else
end if;
end case;
end process;
--out_moore <= std_logic_vector(count_moore_reg);
end arch;
