23
Many old television screens have a very prominent "light grey" color to the glass, I'm guessing from the phosphor, create darker areas if the effect of electrons make the phosphor glow?
Is it an illusion due to contrast between the brightly lit and darker unlit phosphor or can the screen actually darken somehow?
Here are some photos of old TVs from the 70s:
7 Answers 7
87
Forget old fashioned TVs, have you ever watched a PowerPoint in a normally lit conference room? The projector screen is white until you turn on the projector, at which point it seems to become dark grey.
This is because your eyes are sensitive to relative light levels and not absolute. Black doesn't require no light, it's just less light. You can can make a white object dark just by putting something brighter next to it. Projectors, LCDs and CRTs of all kinds exploit this effect.
    \$\begingroup\$ My old TV with much light bleeding approves. Constrast is the most important factor. \$\endgroup\$
    – Sacha
    Feb 8, 2021 at 22:05
  • 15
    \$\begingroup\$ You can always blow somebody’s mind by pointing out that projectors can’t display black. The darkest black they can show is the white of the wall. \$\endgroup\$
    – Michael
    Feb 9, 2021 at 9:28
  • \$\begingroup\$ Not only does black not require absolute absence of light -- it would be atypical. Such absolute absence is not easy to achieve in spaces not designed for it. Even into rooms with no exterior wall surface light seeps in through cracks in doors, panels and ducts, and many everyday devices these days have LEDs. For professional photographic darkrooms, for example, which require extraordinary low light levels, special sealing doors (and blinds, if they had any windows) are required. \$\endgroup\$ Feb 9, 2021 at 11:11
    \$\begingroup\$ As an aside it may be interesting that this fact -- that true "black" is almost never encountered -- was realized by the impressionists at the and of the 19th century and influenced the way they painted (see e.g. designforhackers.com/blog/impressionist-color-theory). \$\endgroup\$ Feb 9, 2021 at 11:21
  • 6
    \$\begingroup\$ This unjustly less upvoted answer electronics.stackexchange.com/a/547023/17817 has one important point missing in other answers: Old TVs were normally placed in a dark part of the room. A strong light shining on the screen greatly interfered with the picture. \$\endgroup\$ Feb 9, 2021 at 13:50
49
It's basically an optical illusion. I never ever remember anything but a very dark screen when I was a kid waiting for "the box" to warm up and then my mum shouting that the TV needed some money in the slot to make it work (damn those rental TVs in the 1960s).
Consider this picture (taken from this wiki site): -
It looks like the "A" square is darker than the "B" square doesn't it?
But if I use paint.exe to sample A's colour and draw a line from A to B we see this: -
You don't have to believe me. Just copy the top image and try it yourself.
Your brain can play some amazing tricks in trying to make sense of the optical info it receives.
    \$\begingroup\$ Rental TVs? Where it was? \$\endgroup\$
    – fraxinus
    Feb 8, 2021 at 10:05
  • 5
    \$\begingroup\$ @fraxinus England in the 1960s \$\endgroup\$
  • 7
    \$\begingroup\$ Thank you. Never even imagined a business model like this could exist back then. \$\endgroup\$
    – fraxinus
    Feb 8, 2021 at 10:28
    \$\begingroup\$ I rented a washing machine in the UK in the late 90s. You could still rent TVs then. \$\endgroup\$
    – D Duck
    Feb 8, 2021 at 11:28
  • 5
    \$\begingroup\$ Rental TVs were quite common. There was a chain called "Radio Rentals" for example. Coin-operated TVs were nowhere near as common, at least by the 80s. Now, instead, there are various forms of rent-to-own, often with very steep interest charges \$\endgroup\$
    – Chris H
    Feb 8, 2021 at 13:26
14
It was not watched in as bright ambient light as a good photo of the tv receiver needs when the camera was supported manually. Or the photo was taken with long exposure time having the camera on a tripod. The old CRT television was placed to as dark corner as possible for good contrast. I have had a CRT B&W television and it was useless if the daylight in the room wasn't dimmed by drawing the curtains in front of the window.
Other aspects: The advertisement photos from 1970's can be heavily retouched for the appearance that was then thought to be the most attractive. They can even have "for ads only" dummy CRT or an inserted mask for easy good looking no-reflection photographing. I guess too dark screen could be seen as "it will stay dark".
I have just now one CRT from 1980's in front of me. I brought it out from the storage only to see it due this case. It doesn't look grey, it's a little green. It's B&W phosphor glows white, not green and it looks substantially darker than CRTs in questioner's ads.
  • \$\begingroup\$ Another aspect to consider is that given that people would watched televisions in darkened rooms, but television sets were not supposed to draw attention to themselves when rooms were lit. A television set whose screen appeared solid black when it was turned off would have been seen as an eyesore. \$\endgroup\$
    – supercat
    Feb 9, 2021 at 16:12
12
Our eyes are amazingly adaptable to ambient light level:
  • We can see in moonlight (but our colour sensitivity is reduced).
  • We can see in bright sunlight.
Yet in each cases, we can see gradations of light (from dark to light). Even small variations in light level are discernible. In the case of a TV screen that starts out "grey" in ambient light, we can discern an even slightly brighter image. The ambient "grey" background is established in our brain as the darkest part of the image. The screen background does not darken.
You ask if the apparent darkening of the phosphor screen is an illusion. Yes....there are a great many aspects of human vision that are illusory, suggesting that much brain processing goes on between eye and conscious perception.
Advances were made over the years in reducing the reflected ambient room light, yielding a darker background. The photo shows two colour CRT screens.
2003(top) vs. 1980(bottom)
The lower (larger) screen is a 1980's era TV while the upper (smaller) screen is a DELL monitor made in 2003. The DELL monitor certainly reflects less ambient light. It also employs an anti-reflection coating that reduces glare.
    \$\begingroup\$ I believe the main difference between the two screens is that the top one has a dark tint added to the glass covering the screen.  That reduces the relative brightness of reflected light, since it has to pass through the glass twice (once in each direction), while the CRT's light only passes through it once.  Of course, the CRT's brightness needs to be greater to compensate, but by the time this became common (the '90s, IIRC), CRTs were plenty powerful enough. \$\endgroup\$
    – gidds
    Feb 8, 2021 at 9:51
  • \$\begingroup\$ @gidds Tints don't stop the front surface reflection, and that one is the strongest. More likely the newer CRT has an anti-reflection coating. \$\endgroup\$
    – J...
    Feb 8, 2021 at 16:46
    \$\begingroup\$ @J... The front surface is shiny and mostly gives a specular (directional) reflection; but it's the diffuse reflection off the back surface (and its phosphor coating) that lightens the whole screen.  And the latter is what tinted glass reduces. \$\endgroup\$
    – gidds
    Feb 8, 2021 at 16:57
  • \$\begingroup\$ @gidds Ah, good point. \$\endgroup\$
    – J...
    Feb 8, 2021 at 17:00
  • \$\begingroup\$ @gidds Another CRT surface treatment by Zenith never really caught on - it gave a really dark surface reflectivity. patents.google.com/patent/US3935036A/en \$\endgroup\$
    – glen_geek
    Feb 8, 2021 at 17:48
If you go a bit farther back in time, to so-called "black and white" TV sets, not only are the other answers correct as concerns contrast, but there's a "color correction" that takes place in our neuroptical perception. We all perceived the images as grayscale, of course. However, if you were observing just the overall light produced, perhaps looking thru a window from outside, or thru a doorway from down the hall, the TV output has a light-violet tinge.
At one of the companies I worked at, there was a room we called "the cave". It was a very dimly lit room for the CAD people doing work with CRT monitors, with the brightness turned down, which resulted sharper images. I still have two CRT monitors (Hitachi CM722, Viewsonic G225FB), and in a dark room, you're getting close to true blacks with these and better CRC monitors. I also have an LCD (IPS) monitor, and in a dark room you see the back lit light coming through producing a dark shade of grey, and brighter if viewing angle is not straight ahead (so if looking at center of screen, the corners are brighter).
However, in a nearly black room, the phosphors on a CRT monitor can give off a glow for a while after the CRT monitor is turned off, and those phosphors can also pick up some energy from ambient light in the room (so just after turning off a light, you get a bit of glow). I assume that OLED monitors or TV's do not have this effect.
Anything to enhance brightest and contrast also raised the power levels needed to transmit thru the aluminum oxide but also resulted in reflections of the phosphor forward.
They applied a thin aluminum oxide film that appears grey to reflect the light forward and also spread heat evenly to the glass then lacquer coated this.
The glass thickness affect transmissibility and reflections, so later this was also carefully tinted with additives that were also slightly magnetic for other reasons and lead to the glass to block harmful XRays.
