I don't understand how to calculate the timings for trigger and reset. The answers are 394.1ms & 11.3s respectively. But I don't know the explanation behind it.
Question & Circuit Diagram
Circuit Diagram Enlarged
  • \$\begingroup\$ What about if you remove the mosfets and treat the diodes as short circuits? Does that help you begin the analysis? \$\endgroup\$
    – BeB00
    Feb 8, 2021 at 5:46
  • \$\begingroup\$ Take the tour in the bottom left. There is a minimum standard for homework questions so once you get started you'll have to show some work. \$\endgroup\$
    – K H
    Feb 8, 2021 at 6:27
