I am currently designing an SMD PCB with an atmega328P. I want to able to feed this circuit using below schematic.
In the past I have had certain heat development issues with arduino boards and all kinds of DC DC converters. The atmega is to be programmed and fed by an ICSP connector. That means I am going to apply 5V to the OUT/FB pin of the LM2596.
Looking at the capacitors and the schottky diode it would be safe. I have however no clue if the LM2596 will do harm. I won't be applying power to the J9 connector at the time of programming.
So with regards to the atmega chip's VCC pin (and the ICSP 5v), should I use an extra schottky diode to be safe or am I just fine without one?
Well I'll take a stab at this. I am not an authority on the matter, but by looking at the internal schematic you should do no harm to the LM2596.
The feedback pin connects to an op-amp that will have no supply voltage.
The output pin connects the the emitter of 3 bjts (which should also cause no issue).
  • \$\begingroup\$ My same opinion too, also the feedback is heavily current limited from the input divider. I would ask TI before doing that for a recommendation, their E2E forum is quite good. \$\endgroup\$ Feb 8, 2021 at 21:59
This is a quite common issue, regulators plugged in live load. In general, you can't. In fact some 78xx for protection requires a diode from the output to the input to at least bias the circuitry (it's their only failure mode, in fact).
Since it's operative from 4.5V up, a schottky from the output to the input would protect it. However keep in mind that you'll be powering the whole 5V rail from the programmer, and that could be bad. I usually switch the supply of the programmer (don't know if the AVR can do that) and program the board running from the internal supply to avoid issues.
You're not really applying 5 V to the FB pin. The LM2596 uses the FB pin to sense the output voltage so that the output becomes 5 V. So the FB pin MUST be connected to the +5 V output, if you don't then the LM2596 will think the output voltage is too low (if you leave the FB pin unconnected) and you will get close to 12 V at the output and that will probably damaging the circuits that only need 5 V.
What does the LM2596's datasheet say? I think there's no need for a 2nd diode so why would it need to be added?
Pro tip: just stick as much as possible to the schematic in the datasheet and you will increase your chance of success.
