19
I bought a powerful tweeter (or so I thought) to experiment with the ultrasound. The device is quite heavy, and it is rated at "350 watts RMS/700 watts peak": 2'' Titanium Super Tweeter PDBT78
Its nominal impedance is "4-8 ohms" with a frequency response of "2-25 kHz".
To make the long story short, the thing burned on me with a sine 20-kHz signal at average (real) power of 9.6 W. How is that possible?! The specs promise 350 W "RMS" (I think they mean average power), yet it burns at under 10 W?! Please review my setup below. Maybe I calculated the power incorrectly and came to a wrong conclusion. This is how I measured the voltage and current:
Measurement Diagram
The scope displayed waveforms for the voltage and the current and showed their numerical RMS values on the screen. When the speaker burned, the scope showed \$V_{RMS}=40\:\textrm{V}\$ and \$I_{RMS}=0.24\:\textrm{A}\$. Thus, I concluded the power was less than 9.6 W. — I don't know how much exactly, because I did not get to measure the phase shift (:
$$P=V_{RMS}I_{RMS}\cos{\phi}$$
Thank you for your interest in solving this puzzle.
PS: I have received a response from the manufacturer:
We test tweeter power using signal EIA-426-B, frequency range 3.5k-20kHZ, PDBT78 power can be 40W ... it has no problem for testing over 8 hours... The 350W RMS is data on giftbox, it is not true data.
This confirms the community answers.
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – Voltage Spike
    Feb 10, 2021 at 16:49
    \$\begingroup\$ With a setup like this, you can burn up your ears as well. Near-audible ultrasound is just as bad for ears as an audible sound with similar power. It may be even worse because loud audible sounds are unpleasasnt and make you plan your next experiments better. \$\endgroup\$
    – fraxinus
    Feb 12, 2021 at 9:22
5 Answers 5
35
Your linked description shows that the tweeter is intended to be used with a woofer for music reproduction. The description doesn't cover use of the tweeter as a specialist ultrasonic transducer on its own. The power rating indicates that the tweeter is intended to be used with a 350 W average/700 W peak audio amplifier driving both tweeter and woofer. For normal music or speech the average level is 10 dB below the peak level, bringing the peak level down to 70 W, much of which is feeding the woofer. In order to ensure the bulk of the power actually does go to the woofer the tweeter impedance is, as you found, much higher than 8 Ω. The 4-8 Ω rating in the specification indicates that the tweeter is intended to be used with a 4-8 Ω woofer, not that the tweeter itself has a 4-8 Ω impedance.
The Pyle description is written to be easy to understand for someone with modest technical knowledge putting together a car audio or other speaker system. The description tells them that if they have a 350 W amplifier and a 4-8 Ω woofer then this tweeter is suitable to use with them. It doesn't mean that you can put 350 W into just the tweeter.
  • 9
    \$\begingroup\$ It turned out you can't even put 10 W in the device. I think this is an obvious case of false advertisement:. The manufacturer or seller never mention that woofer has to be connected in the description of the product.. This make the "power" number very poorly defined. Thank you for the explanation, though! <br/>What can be used as inexpensive US radiator? \$\endgroup\$
    – SlowBot
    Feb 10, 2021 at 0:02
  • 4
    \$\begingroup\$ I did not expect 300 W, but 10 was disappointing. I feel the average person who is buying these products is misled too. Look at the number of posts about failed speakers, replacement coils, etc. \$\endgroup\$
    – SlowBot
    Feb 10, 2021 at 0:20
  • 21
    \$\begingroup\$ The first paragraph of your linked description states this tweeter "will complete your current car woofer enclosure system for full-range stereo sound reproduction". The advert mentions "car" six times. Whilst I'm sorry you've burnt out your tweeter the advert seems entirely clear that it is talking about car audio use and not standalone transducer use. If you ask Pyle I expect they can give you technical data on standalone use. There's no point putting that into an advert aimed at car audio users as it would mean nothing to them. \$\endgroup\$
    – Graham Nye
    Feb 10, 2021 at 0:30
  • 5
    \$\begingroup\$ @SlowBot Is is still misleading when the numbers are so clearly ridiculous? There's no way even 40 W steady state could be pushed into such a device without it being thoroughly cooled (either with water or a big heatsink and a fan). Where would all that power go? Think of a 40 W lightbulb and how hot that thing gets how quickly. The coil of the speaker would have done the same. \$\endgroup\$
    – TooTea
    Feb 10, 2021 at 9:24
  • 8
    \$\begingroup\$ @SlowBot Putting 350W continuously at 20kHz through a tweeter inside a car would leave you clinically deaf within a few minutes (assuming you could withstand the pain level). At the rated sensitivity, that would be like standing close to a military jet engine with no ear protection. As the answer says, this is meant to be used as part of 350W total audio power. \$\endgroup\$
    – alephzero
    Feb 10, 2021 at 13:54
21
It appears that the problem lies with the power ratings of loudspeaker components being the power rating of the system and not that of the individual component.
For example, in the 1970s, Philips were specifying the ratings of individual speaker components.
In later years, it may have been felt that specifying the system power would make it easy to select individual components while configuring a system.
The statement in the following specifications confirms that.
'System powers tabulated below are for complete two or three-way systems making use of the listed loudspeakers; corresponding cross-over networks and recommended enclosure volumes are listed on pages 4 and 5.'
A pair of loudspeakers, configured by Philips years ago, had the following components:
Woofer - AD8061W - 30W
Mid-range - AD0210 - 20W
Tweeter - AD01610/T - 4W
It shows that the tweeter power is indeed quite low when compared to the system power.
  • 7
    \$\begingroup\$ A great retrospective on how everyday life is made "easier" encouraging us to get dumber. \$\endgroup\$
    – SlowBot
    Feb 10, 2021 at 14:06
  • \$\begingroup\$ Thank you, SlowBot. \$\endgroup\$
    – vu2nan
    Feb 10, 2021 at 18:18
11
I'm afraid that you are another Amazon victim. I note that you have linked to an Amazon ad rather than a manufacturer's datasheet which would explain how the device is rated and expected operating conditions. Our motto here is, "No datasheet? No sale!".
I expect that a similar device from a reputable manufacturer might give the amplifier rating at several hundred watts but when used with a passive speaker crossover setup which might filter out a lot of power.
"The specs promise 350 W "RMS"." That's usually a big clue that we're dealing with bad marketing hype. Power measurements don't use RMS as the "square" term is already built in to the power equation P = V2 / R.
    \$\begingroup\$ @SlowBot They may be reputable, but they still need to operate in a world where all their competitors advertise hundreds of watts, so they wouldn't sell anything if they stuck to the physically correct ratings of like 4 W continuous. \$\endgroup\$
    – TooTea
    Feb 10, 2021 at 9:26
  • 7
    \$\begingroup\$ A correction to your last paragraph. "Power" certainly does need "RMS" specified, because it does not inherently cover the "root mean" part, and your statement for power calculation is only true for a resistor which a speaker isn't. "Instantaneous power" is very much a thing. Also in the audio world it's important to be clear what's RMS (hence actual power) and what's a dodgy marketing number like PMPO. Seeing RMS is actually the sign of a number you can reasonably expect to achieve. (Or as the OP has found, a repeatable reference value.) \$\endgroup\$
    – Graham
    Feb 10, 2021 at 18:49
  • 4
    \$\begingroup\$ @Graham: But "RMS" is not the correct way to average power. You want simply "mean power". For linear circuits, there is a relationship between mean (not RMS) power and RMS voltage and RMS current. \$\endgroup\$
    – Ben Voigt
    Feb 10, 2021 at 22:01
    \$\begingroup\$ Strictly speaking the term "RMS Power" is devoid of physical meaning. What quantity do you get from multiplying power by power? (Of course it can be calculated from the instantaneous power, to provide the RMS statistic.) \$\endgroup\$
    – SlowBot
    Feb 11, 2021 at 0:00
    \$\begingroup\$ @SlowBot ":I thought Pyle was a reputable company. I've written them, but so far no reply." I'm an audio guy, mostly with pro-level stuff. Pyle is a cheap consumer brand and thinks/operates that way, sometimes with 19" rack ears glued on afterwards. They have their place, and I've used them before, but you often get what you pay for. \$\endgroup\$
    – AaronD
    Feb 11, 2021 at 19:43
11
The power ratings for audio equipment are often completely bogus. Check out the amount of copper in a 350W motor (and note that a speaker is also essentially a motor, only the motion is linear instead of rotational):
There's nothing in the photo for size comparison, so I'll just note the diameter is about 5" (13 cm).
Guessing a power rating from a photo is akin to palm reading, but your speaker indeed looks like it could handle a couple of Watts, certainly not hundreds. I assume the 2" in the description refer to the size of the magnet, so the coil diameter is probably less than 1".
PS. Try to get your money back from the seller. There's nothing dishonest in claiming the speaker was defective, after all, you didn't exceed its maximum ratings, did you?
  • \$\begingroup\$ It might be an uphill battle to get a refund, since it wasn't in the manufacturer's intended use. But it WAS within the STATED ratings. So that might be an advantage. I wonder what would happen if lots of people did that? Effectively called out the "easy to match", pre-engineered specs that are spectacularly wrong in isolation. \$\endgroup\$
    – AaronD
    Feb 11, 2021 at 19:53
  • \$\begingroup\$ And +1 for consumer-accessible audio specs being almost useless. They can show you the math and the test methods, and that all lines up, but it's all designed not to be an indicator of actual use, but to make a bigger number that they can "truthfully" advertise. \$\endgroup\$
    – AaronD
    Feb 11, 2021 at 19:57
  • \$\begingroup\$ @AaronD The batlle might easier that it seems. Refusing to reimburse a defective product opens the seller/manufacturer to a lawsuit, and using an audio speaker for arbitrary sound generation (as opposed to playing music) falls under the category of "reasonably foreseeable use", unless the product manual specifically lists product use cases (check out your laptop charger for an example of such a warning). Unless the shop is flooded with money-back claims, they wouldn't risk it because they know their product description won't stand up in court. \$\endgroup\$ Feb 12, 2021 at 10:48
  • \$\begingroup\$ But IS it defective? It's designed for a total system with X specs, and that's what it's advertised for. If it's not used within that context, they can claim that it's outside of the intended use, and so "the user exceeded the spec." For an even lower example of seller integrity, I actually had a high-rep eBay seller argue with me about their 8AWG jumper cables (I measured them) with super-thick insulation in a package labelled "4AWG" and sold as such. It went all the way to eBay's arbitration, which immediately reimbursed me, despite multiple protests from the seller to not go that far. \$\endgroup\$
    – AaronD
    Feb 12, 2021 at 14:22
  • \$\begingroup\$ @AaronD If the usage instruction states that the tweeter "is designed for a total system with X specs", then it's the user's fault for not reading it (they should have returned it under "product not as advertised" clause, but without breaking it first). If it simply says "350 watts RMS/700 watts peak", it is reasonable to assume the device is designed to withstand such power. Either the seller takes it back as defective, or they admit false advertisement. \$\endgroup\$ Feb 12, 2021 at 15:53
Impedance
I'm going to start by addressing only one (admittedly rather minor) point raised in the question--that of the impedance.
The impedance of a loudspeaker isn't a single fixed number. It's generally a curve that will look at least vaguely like this (hand drawn, so don't try to read too much into the details):
That tall, narrow spike is at the speaker's free-air resonance (fs).
The rated impedance is then at the first minimum above the free air resonance (roughly where I've drawn in the red, sort-of vertical line).
You usually won't drive a tweeter at anything close to its free air resonance frequency though. Its free air resonance might be at, say, a couple hundred Hertz, but the crossover from midrange to tweeter might happen at, say, 3 KHz.
As such, it's not only reasonable, but entirely expected that for a tweeter, its impedance throughout its entire normal range of operating frequencies will be (often substantially) higher than its rated impedance.
Power
Getting back to the power situation, I'd agree with those who've pointed out that a normal tweeter would never be expected to handle a power input of tens of watts, not to mention hundreds of watts.
I'd add, however, that the amount of power a tweeter is expected to handle is rarely a function of the sounds its really intended to reproduce. Rather, it's almost entirely a matter of how much abuse the manufacturer expects the tweeter to be subjected to. When/if you drive a bipolar amplifier beyond its capabilities, it will clip. This will typically result in drastically increased power at higher frequencies. A FET- or tube-based amplifier will also clip, and when it does, the power and higher frequencies increases as well--but this happens much more...violently with a bipolar amplifier. Exceeding its power capabilities even a little bit can increase harmonic distortion from a bipolar amplifier a lot, whereas with a tubed amplifier you have a fairly broad range in which you can increase power output with gradually increasing distortion.
Reproducing normal music requires very little power at higher frequencies, so the power handling capability of a tweeter primarily reflects the manufacturer's estimation of how likely you are to drive your amplifier into clipping (and/or how much clipping they think you'll tolerate).
  • \$\begingroup\$ Sure, a product is not expected to have a good performance at its maximum power rating, but it is expected to withstand it. \$\endgroup\$ Feb 12, 2021 at 10:59
  • \$\begingroup\$ @DmitryGrigoryev: Yes, but the question is whether that rating is for the tweeter itself, or a complete system in which the tweeter would be used. To anybody who starts out with even a general notion of what they're looking at, it's obviously the latter. The only part open to question is whether the advertising he read actually mis-characterized the rating, or he simply misread what was there. \$\endgroup\$ Feb 12, 2021 at 15:58
  • \$\begingroup\$ I suppose only the OP can check what is actually written in the manual/instructions/whatever document they got with the speaker. If it mentions what the power rating stands for, then sure. \$\endgroup\$ Feb 12, 2021 at 16:07
