I have a requirement to build a circuit which can identify 3 states at the input and the output is given to ADC of uC. I have the below circuit for 12 V systems:
The input can be connected to gnd, battery(T87) or left open. I am trying to use the same circuit for 24V system but since the ISO pulses(have to consider ISO pulses since input can be connected to battery) would go up to +- 600V in the 24V system, what are the changes that I will have to make. I have to probably change the resistor values and packages. What about the diode ? what are the parameters that I have to consider for diode selection ? and what would be the worst case for the diode, for example like Jump start, load dump , ISO pulses, reverse polarity ? the switching diode BAW56W was chosen for 12V system because it was already available in the BOM of our product.
Here is the link to my other related question, I was not too clear while asking that question. My main requirement is that my circuit differentiate between 3 states Automotive electronic circuit design, Voltage divider to uC ADC pin
