I would like to use an SMD assembly service in order to pick and place the components directly to my PCB. There is a DC-DC boost converter (DD06AJSA) on the board which includes an inductor:
I need to boost a 3,7V lithium battery up to 5V with a current draw of 500mA.
Is it possible to use a ceramic inductor instead of a wire wound inductor with the same value, so 6.8uH, like in the following picture?
Also: Unfortunately I have just 4.7uH as a choice, so would it still work as expected if I would choose a slightly lower one? In the datasheet for this IC FP6291 a value between 3.3uH and 4.7µH is recommended.
