Im trying to do a DIY RC car with uses two 6-12 V motors as well as some LEDs, servos, and Arduino components.
I was planning on using four 3.7 V, 2600 mAh, 25 A 18650 battery cells, two in series and two in parallel, so as to end up with 7.4 V, 5200 mAh.
I'm using this picture to use the batteries from this website. The thing is, would this work without problem with 18650 cells? Do I need to add things between them or just simply add a 2S BMS (Battery Management System) to both the positive and negative?
  • \$\begingroup\$ What’s a 2bms? You mean a charger that monitors both cells? \$\endgroup\$
    – user69795
    Feb 13, 2021 at 0:20
  • \$\begingroup\$ How do you intend to connect them together? \$\endgroup\$ Feb 13, 2021 at 0:44
Probably fine. Wiring details may matter if you discharge at a very high rate. Because each wire acts like a small resistor. If the resistance is not equal in all pathways then the cells may not share current equally during charge and discharge.
Also, don't connect batteries together in parallel unless and until you somehow get them both at the same voltage (by charging them or discharging them or connecting them together with a resistor for a long time or something).
Also also, if you don't plan to balance charge, then you should also manually balance all the cells before you put them together in a pack.
As far as putting something between the cells, I don't think that is typically done in small packs. Ideally you would put a fuse in series with each cell. Certainly for battery packs with many parallel cells this would be mandatory.
But this is usually not done in RC. In RC, people usually take precautions to make sure nobody gets hurt if/when a battery pack catches on fire. This is a different standard from consumer products which need to be much safer than that.
  • \$\begingroup\$ By balance charge, would a 2S BMS help? \$\endgroup\$
    – Marcelo_M
    Feb 16, 2021 at 22:37
  • \$\begingroup\$ Balance charge means your charger connects to the in-between point of the 2S cells to make sure that all cells in series get charged equally. The BMS can sometimes also perform some limited balancing, but it is not intended to balance a pack that is assembled with cells that are severely imbalanced. Just charge all the batteries before you assemble them into a pack and you should be OK. Check the voltage with a meter before connecting cells in parallel with each other. 0.1V or less difference should be OK. But don't connect a 3.8V cell to a 4.15V cell, for example. \$\endgroup\$
    – user57037
    Feb 16, 2021 at 22:45
That series-parallel arrangment is legal but could give some issue since cells will not be discharged in the same way. It will works but you'll have less than 4 times the capacity, probably.
Usually is preferrable to put all the cells in series and step down from the resulting voltage with a converter; even in that case there are cell balancing issues at some point (and dedicated ICs to resolve them!)
As for the battery protector: each pack must have its one, they are not designed to protect multiple packs (unless they are redesigned accordingly). You do not want a lithium fire on the bench, I assure you.
