I bought a 24 V shower booster pump,
and it has this crazy behaviour that it shuts down after 10 - 12 seconds. When I restart the pump, it starts again for 10 - 12 seconds.
It is useless now and pumps that do not have this "feature" are outside my price range.
A simple solution would be to restart the pump every 10 seconds, with 0.5 second paused.
But how to make a looping relay that is NC for longer time and NO for a really short time??
Edit: No, no schematic of the pump, just + and -. Inside sealed with epoxy.
No, not a pressure switch. If I limit the incoming water flow it should take different time to reach pressure. Always about 12 seconds (not stopwatch)
Thanks for thinking with me, but obviously I thought of those.
Sure, there is flow sensor to start the booster pump when the water starts. Why the heck they built something inside to stop after short time?? And don't restart until the water stops, and starts again, or the power is interrupted.
I found with the help for correct search terms the following hardware:
It can do continuous loop at different timings for stop and start.
I totally agree that this is not the best way. The pump should work continuous without this type of trouble. Thing is, dry testing one doesn't do for long 10 second period, the fault is not detected. After installing, there is no longer any opertunity for return or warranty
Note: It's not being used for shower, but to boost water pressure coming from a deep well pump. After 35 meter that is pressure too low to be used for spraying the plants outside
