I recently migrated from old Orcad to Altium, and so I often run into things that work differently. One of these things is adding extra text labels to a component in the pcb editor.
A good example is a board with multiple onboard switches. You'd want a label indicating what each switch is for and also labels for each position of the switch. In orcad this was easy. When attached, the labels would move along with the component when that was repositioned accross the pcb.
Is this possbile in Altium? I could think of using the comment property, but then that would mess up the bomdoc.
