I want to use this boost IC to drive an LED string.
I have 9 LEDs. 300mA forward current and 3V as typical Vf.
Can someone guide me on how to set the output voltage of the LED string using that IC?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI want to use this boost IC to drive an LED string.
You don't set the voltage.
It is an LED driver. You set the current, and the voltage takes care of itself.
Set the current using \$R_{VFB}\$ as described in equation 5. For 300mA, it looks like you'll need a one ohm resistor.
As long as the sum of the forward voltage for all of your LEDs in series is less than 60V, it'll work.
