i have made a small circuit using ESP-12E here is how my circuit looks like:
Here i have kept in mind that wifi connection should be stable, still i am not able to get the stable WiFi connection. Reason is still unknown to me.
  1. I kept the WiFi antena without below ground plane. So it won't create disturbance in WiFi signal.
  2. I kept the capacitor as close as possible to VCC, but its far from ground, not sure how i could make it close to that.
  3. No complex component is near the ESP8266 chip on the board.
Not sure what is making it unstable. Any suggestions how can i improve its stability in this circuit design.
Thank you!
  • \$\begingroup\$ Basically, you need a ground plane. \$\endgroup\$
    Feb 17, 2021 at 12:43
  • \$\begingroup\$ @Andyaka where? \$\endgroup\$ Feb 17, 2021 at 12:59
  • \$\begingroup\$ On your circuit board. \$\endgroup\$
    Feb 17, 2021 at 13:04
    \$\begingroup\$ I think you need to examine what is meant by a ground plane. Your blue copper is nothing like a ground plane. \$\endgroup\$
    Feb 17, 2021 at 13:06
    \$\begingroup\$ You should always avoid running traces on the ground plane as much as possible. You have essentially a bunch of useless copper islands cut apart by traces, instead of a ground plane. \$\endgroup\$
    – Hearth
    Feb 17, 2021 at 15:38
Your signal and power traces have no ground return path beneath. That alone might be the killer here. If in doubt, the easiest way to achieve that is a contiguous ground plane under all traces.
The fact that you didn't put anything beneath your antenna is good, but not sufficient: Your buttons and traces right next to the antenna are as important as the things beneath it.
In fact, Espressif has a design guide and it's not really hard to follow. They even have a visualization where to put the antenna (and hint: where to not put it, and that's within the board outline), and it looks like this (pick one of these positions, not multiple):
antenna placement
If you really need to place things next to your antenna, leave 15mm space around it. That includes PCB substrate.
keepout
So in conclusion:
  1. don't put anything next to the antenna. Don't even put PCB material below the antenna (but honestly, PCB below that just loses you a few dB of signal, at most, due to mismatch and material losses; metal next to the antenna can distort your antenna diagram significantly, and/or absorb a majority of energy.).
  2. Don't route signals on top and bottom: your board is not that complex. Leave everything on top, and if you need to "bridge" something, wherever possible, just elegantly route it beneath a connector or passive component
  3. Have a ground plane, on the bottom side.
  4. Have good ground connectivity. So far, your module is connected to ground but through a single via (that's kind of OK), but your decoupling capacitor is reduced in usefulness, because it's "barely" connected to ground (for RF signals), only through a long trace instead of through a via to a large ground conductor (e.g. plane) very close to the capacitor).
