Does anyone know how to fix this? One day my SSD died and after a system restore, I found a clean list of printers. I tried to reinstall MG EE but the problem persists.
\$\begingroup\$ Are there printers showing in your Windows Printers Control Panel? \$\endgroup\$– jwh20Feb 17, 2021 at 15:28
\$\begingroup\$ Yes. Moreover, Xpedition Layout sees all printers and prints without problems. \$\endgroup\$– Ruslan FatkullovFeb 17, 2021 at 15:32
This helped for me:
https://support.sw.siemens.com/en-US/knowledge-base/MG603980
Solution:
In Windows 10 Settings> Printers and Scanners, uncheck "Let Windows Manage My Default Printer"
The workaround is to select another printer as the default. For example, set "Microsoft XPS Document Writer" as the default, and now the printers are listed in Designer, under File> Print
