What would I need to add to set up to get 2 outputs at 12 volts. Outputs are 0 and 1. I would assume relays. Signal Outputs. For a 3 Position 12V Solinoid. Micro 820 2080-LC20-20QWB
  • \$\begingroup\$ what kind of outputs? signal? load? more details please (edit the question, no need to put in comments) \$\endgroup\$
    – Pete W
    Feb 17 at 20:23
  • \$\begingroup\$ What 820 are you using? Depending on which one you should be able to use 12V directly on the relay outputs using the COM and OUT... \$\endgroup\$
    – Ron Beyer
    Feb 17 at 20:25
  • \$\begingroup\$ I figured it out. added 2 24 volt relays for outputs. Actuated the valve perfect. Thanks \$\endgroup\$
    – John S
    Feb 18 at 16:29
