I generate an analog voltage from PIC microcontroller output. I want to transmit this analog signal to maximum distance as much as possible using single wire. I have non-inverting OPAMP at the output of PIC pin.
Which configuration best for this maximum driving purpose?
- Without OPAMP, direct driving from PIC
- Unity gain OPAMP, R45=open, R46=0ohm
- With some values of R45 and R46. Noninverting topology.
