I need a way to automatically turn on/off mute (basically "emulate" pressing the mute key) in a car audio system when one signal changes it's logical state. Without MCU this could be done with edge detector circuit based on XOR gates, like this: edge detector circuit
So adding some protection & rest, I've came up with the following circuit: Circuit
D1 & D2 are some protection TVS diodes, R4 limits current for TVS diode while it should pass more than enough current for U1. Gate A forms a sort of "filter" and gate B with R3/C1 basically sets delay.
As long as I place LED in series with R6 it works as intended - LED blinks for a while on input level change.
The issue is actually where it comes from the actual audio controls itself. As I was helping for a friend I wasn't aware of the audio controls for a while before I drew this schematic. Next it turns out to be analog control where resistance sets command: audio control
Digging further for those systems, I've came with the following schematic for other audio system which seems to work on the similar principle: other audio controls
So basically it seems to have a voltage divider formed which feeds the resulting voltage somewhere. I assume this could be some sort of ADC inside. The question is - will it work with N-channel MOSFET? Because I don't know the internals of it's input. One thing I know for sure - that once the required button are pressed it connects +Vcc via measured resistance to an output. But I don't know what's the impendence of the input do I have to use P-channel MOSFET with inverted logic here? Any suggestions welcomed.
PS: Assuming +Vcc = +12V.
Before I go any further, you should consider using a microcontroller for this. I know this is a really simple circuit, but unless you know the signal source will never have short pulses you could end up losing a mute press somewhere and annoying the user. I'm assuming the function here is to mute the radio when another sound source is present. A microcontroller based solution can guarantee it waits the necessary time before pressing mute again. It would take maybe a dozen lines of code. You should get some ATTiny boards and familiarize yourself with them. You'll be glad you did.
A MOSFET will work just fine, be sure to drive the gate to a higher voltage since the circuit on the other side of the mosfet could be at +5V. Since you have access to the 12V supply it's easy to drive the gate to 12v which will ensure turn on.
Here's how to do that with a somewhat simpler edge detector circuit:
link
On the top left and right there's the switch module with resistors and the thing that reads it. In the lower left there's the new circuit that fakes a button press. It uses a 3.4K resistor (the value the switch module has when the mute button is pressed). The MOSFET acts as an electronic switch that can be turned on to switch the resistor in. I also included a simpler transistor based edge detector circuit. The capacitor can be changed to adjust the pulse time.
If you already have a logic circuit built or prefer to use logic chips to analog stuff, you can just wire the output of that to a MOSFET gate as in the circuit below and omit all the messy resistor and transistor stuff.
link
If you add another MOSFET then you can guarantee it will work regardless of the voltage on the other side. This is the circuit used in analog switch ICs albeit with back to back N and P channel transistors since those have to block voltage in both directions.
  • \$\begingroup\$ Thanks for your answer, but I've noted in PS - Assuming +Vcc = +12V, i.e. the gate drive and signal voltage are at the same levels. That is there comes an issue. \$\endgroup\$
    – NStorm
    Feb 20, 2021 at 4:14
    \$\begingroup\$ I added a third circuit which should handle that possibility. You could probably get by with only 5V gate drive on the N FET if you're including the P channel transistor. tinyurl.com/yccu3utx as long as the threshold voltage on both FETs added together was below 5V. Assuming you use a logic level N and P fet that condition holds and you save a few components \$\endgroup\$ Feb 20, 2021 at 4:35
  • \$\begingroup\$ It's unlikely that you'd need it though. The microcontroller inside the radio will be doing two things. First, noticing that a switch is pressed, and second, reading the voltage on the positive pin to know which switch that is. It's unlikely that it takes more than 9V to wake it up and once the bottom rail is grounded the N FET will be fully on. They could also be switching in a lower value pull up resistor with the negative wire always grounded such that pressing a switch momentarily pulls the positive line close to zero but that too will work with just the N FET. \$\endgroup\$ Feb 20, 2021 at 6:40
    \$\begingroup\$ This is roughly what I expect the radio actually does. tinyurl.com/y7dph8sz First the radio is woken up by a logic high on the negative rail. It closes a switch to ground the negative and samples the voltage on the positive rail, then it opens the switch and know the button is released when the negative rail goes low again. \$\endgroup\$ Feb 20, 2021 at 21:12
