I have an application where I have a sensor which communicates with an FPGA with about 15 differential pairs of data clocking around 300 Mhz. Due to constraints, the board can't be taller than 35mm and the surface mount header which receives all this high speed data has to go horizontal smack dab right in the middle of the back of the board. This leaves no room on the front of the board for the FPGA not to overlap the sensor header on the back. Now technically they are both surface mounts so you could say it isn't a problem, however the FPGA (Artix7 200T) has high frequency bypass caps requirements which are supposed to be put on the opposite side of it right where the header has placed itself. I am wanting to know if anyone has design horse sense from experience as to know if it is less risky to
- shift the FPGA 2 to 3 cm off to the side to get it off from behind the headers which would lengthen the differential pairs or
- Make exceptions for the proximity of the high frequency caps on the back of the FPGA?
I will eventually have more experts looking at this but need initial decision just to get keep things going until I can get to that point.
