How does the shutdown pin of the AP2127 work? If i pull the shutdown pin to vin, will the output be enabled? Or is it the other way around?
Thanks
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThe fact that there's a bar above the "SHUTDOWN" means that it's inverted. I.e. "shutdown" is active when low.
If you thus pull it high, then shutdown will be disabled, and your chip will be active.
