I am trying to better understand practical applications for bonded metal laminations and insulated epoxy coating. I started a new job at a company that does this and I am so lost. Any insight would be greatly appreciated, thanks in advance!
New contributor
alyre-like-the-jet is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
    \$\begingroup\$ Can you edit to explain what you do know to avoid people wasting time explaining that? \$\endgroup\$ – Transistor Feb 23 at 22:22
  • 4
    \$\begingroup\$ Honest advice: the best experts on your topic are your colleagues, and "learning on the job" is kind of normal. How are we supposed to know the "practical applications" for what your company produces better than your colleagues? \$\endgroup\$ – Marcus Müller Feb 23 at 22:22
    \$\begingroup\$ Corrosion may exist anywhere metal exposed to moisture and so powder coated epoxy prevents this if done well. Hot zinc coating is done where the metal must conduct and may coated with Nickel \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 23 at 22:58
  • \$\begingroup\$ Thank you all, I am completely new to the electronics world, even the terms are foreign to me. I have done some research and find it too vague. My colleagues make bonded stacks and do insulated epoxy coating, but we never see what the end product is being used for. (Mainly aerospace and defense, I assume due to the confidentiality issues). I am new here and apologize if this is the wrong forum for my questions. Thank you kindly to those who have responded. \$\endgroup\$ – alyre-like-the-jet Feb 23 at 23:32
Bonded metal laminations and insulated epoxy coating. Hmm. . . Sounds like your company makes transformers. Have you looked into the making of transformers. The process used for making these is very close to what you're describing. Look into it. It might help explain what you're looking to understand. Hope this helped.
New contributor
Henri Coderre is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
    \$\begingroup\$ Motors are another significant possibility. \$\endgroup\$ – K H Feb 24 at 1:31
  • \$\begingroup\$ Greatly appreciate your time and insight. Thank you! \$\endgroup\$ – alyre-like-the-jet 2 days ago
