I want to make a variable VAC power supply, maybe using 3-5A transformer. I provide the simple circuit diagram below.
220 VAC to Variable VAC
What should I add to ensure its safety? Thank you.
New contributor
Respati is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • \$\begingroup\$ How about a fuse? \$\endgroup\$ – jwh20 Feb 23 at 23:36
    \$\begingroup\$ Fuses on both sides. Switch to be break before make to prevent shorting the windings during switching. \$\endgroup\$ – Transistor Feb 23 at 23:37
Respati is a new contributor. Be nice, and check out our Code of Conduct.
