I am an absolute beginner to PIC microcontrollers. I am using PICKit3 to program a PIC18F4550 and MPLABX-IDE / MPLAB IPE version 5.20.
The problem I'm not able to solve is that the connection to pickit3 always fails and I don't know why. I looked at countless similar questions but none could solve the problem. Here are the complete details:
PICKit3 Programmer
PIC ICD2 PICKit2 PICKIT3 Universal Programming Adapter Programmer Board
MPLAB-X IDE / MPLAB IPE v5.20
OS: Ubuntu 16.04
The first problem I was getting was that my USB port was supplying 4.750000 volts instead of the required 5V. So I used an Arduino as an external power source.
Connection diagram:
And the MPLAB IPE Screen:
    \$\begingroup\$ Did you read the manual? Your diagram lacks ground connection between Pickit and target. And the supply voltage connection too. And there is no pull-up resistor on the MCLR. \$\endgroup\$
    – Justme
    Commented Feb 24, 2021 at 7:52
  • \$\begingroup\$ Try sticking the chip in a breadboard and connecting the programmer to the right pins with jumpers. Make sure the programmer is configured to supply power to VDD. \$\endgroup\$
    – Drew
  • \$\begingroup\$ I'm not sure if you need the MCLR pullup for programming, but you could try adding it. \$\endgroup\$
    – Drew
    Commented Feb 24, 2021 at 7:53
  • \$\begingroup\$ If that doesn't work double check your connections, and then try a new chip. It's fairly easy to burn them out with you connect the programmer incorrectly. \$\endgroup\$
    – Drew
    Commented Feb 24, 2021 at 7:54
  • \$\begingroup\$ I checked the connections, they're correct. I will get a new chip and try on it. \$\endgroup\$
    – RishiC
    Commented Feb 24, 2021 at 8:35
