This is an extension to the question "Safely housing a power supply" asked by Harry Braviner.
I plan to use a very similar power suppy as the main compnent:
In my case the need is to power a 24v 130w motor to drive a clockmaker / watchmaker 8mm lathe. A speed controller will be separate and not contained within the power unit housing. The lathe will be mounted on a stand which is about 4" deep and has a central slide out drawer, but that will leave an underside compartment ether side of the central area, which might be large enough to house the power supply subject to the answers I receive. Alternatively I'll build the supply as an external power brick with a fly lead that plugs into a socket on the lathe cabinet. A controller for the motor speed will be mounted on (or beneath) the lathe stand.
My questions are:
- The answer to the original question recommended a metal junction box. Could a rigid plastic box be a safe alternative if the heat from the power supply is fairly low (or is it best to play safe and use a metal box)?
- Is a ventilation fan likely to be needed, or can that be determined only by experiment?
- If the power block is kept exernal (like a laptop) wth a fly lead to a socket on the lathe base, what style plug and socket would be appropriate to use that can take the likely current?
many thanks in aniciption,
