I'm trying to design an EMI filter for a buck converter and I'm following steps on: AN-2162
Here is the question:
At page:6, for the Cf capacitor; two different capacitor values are calculated and highest value is taken(Cfa, Cfb). In my situation, calculations for Cfa results a negative cap. value.
Since there is no negative capacitance, should I neglect this result or take it as a positive value?
Here is the calculation:
Cin=2uF(0.000002F)
L=1mH(0.001H)
fs=30kHz
for Cfa:
0.000002 / ((0.000002) x (0.001) x (((2 x 3.14 x 30000)/10)^2)-1)
0.000002 / ((0.000002) x (0.001) x (355000000))-1
0.000002 / (0.71-1)
0.000002 / -0.29
= -6.89uF
  • \$\begingroup\$ Is that from section 4.3 which says "Pick the higher value determined by the following two formulas" and gives an alternative formula? \$\endgroup\$ Feb 25, 2021 at 11:40
  • \$\begingroup\$ @AndrewMorton yes, I got one of them negative. \$\endgroup\$
    – Das D.
    Feb 25, 2021 at 11:44
  • \$\begingroup\$ And so which one is the higher value? Use that. (E.g. 5 is higher than -10.) \$\endgroup\$ Feb 25, 2021 at 11:45
  • \$\begingroup\$ -10 is not a valid value for capacitance, that's why I ask for it, I thought maybe minus sign has no importance here and it may become: 10 is higher than 5 \$\endgroup\$
    – Das D.
    Feb 25, 2021 at 11:51
  • \$\begingroup\$ Please check the APEC seminar I taught in 2017 in which I show in slide 80 how to design an EMI filter for a buck and how to optimally damp it. \$\endgroup\$ Feb 25, 2021 at 12:27
Are you really sure you did the computation correctly? In equation (5) Cfb can be negative only if is negative either of
  • Lf : negative inductor? no, check
  • The thing after that? no, it's squared so it can't, check
Given that there are no complex numbers in that formula I don't get how you can get a negative value
  • \$\begingroup\$ I'm sorry, Cfa is negative. \$\endgroup\$
    – Das D.
    Feb 25, 2021 at 7:52
  • \$\begingroup\$ @DasD. Show how. \$\endgroup\$
    – winny
    Feb 25, 2021 at 10:46
  • \$\begingroup\$ @winny values are edited \$\endgroup\$
    – Das D.
    Feb 25, 2021 at 11:32
This site is temporarily in read-only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
