PROBLEM: Considering the figure below, I need to select an appropriate bank of capacitors for a 3 half-bridge brushless controller, which system have this characteristics:
- VM = 60v (maximum);
- Max Current = 100A;
- PWM frequency: 100khz;
- Rds(on) typical is 1.15mOhm;
- Rshunt = 1.0mOhm.
QUESTIONS:
1- What SMD package is recommended to use for these capacitors? (I'm considering to use 1206 or 1210)
2- For the capacitance, the higher the better?
3- For the number of capacitors, the more the better?
4- How to calculate a proper C for the capacitors?
LAYOUT INTENTIONS:
The bulk caps will be placed as shown below, in order to get the minimum current loop:
Top Layer:
3D View from Top Layer:
