Below is flow diagram of my pcb power side, the issue is when relay turn on a 12V 30 watt heater element the voltage drops (or swing) and stay down until load disables. This drop cause issue on my amplifier circuit and I want to know why other regulator dont regulate the voltage back to normal. (I have tried external AC/DC converter with Rigol DL3000 DC load and voltage drops too)
The most interesting is this does happen some time and some time by just turning on and off unit it goes away but mostly is over there.
Note: 5V buck regulator below is typo
Below graph shows' the input supply when load turns on and off
Below graph is 12V buck boost regulator (Different recording)
External Supply : RACM230-24SG Output 24V 9.58A 80 ~ 264 VAC, 120 ~ 370 VDC Input
Let me know if I you need more info
