Question about the correct mathematical model for a branched transmission line
Baseline Setup
- Waveform generator: Output 10-60MHz sine wave, 8Vp-p, Output impedance 50Ohms
- RG58 50Ohm coax: propagation speed 0.659c (length ~0.5m, but that should not be relevant)
- 50Ohm "feed through" terminator connected to
- 200Mhz digital oscilloscope
Result: 4Vp-p sine wave. Amplitude flat across frequency range. 50% attenuation, as expected, due to "voltage divider" of the 50Ohm source with 50Ohm terminator
Interference Setup
- Add a coax-T before 50Ohm feed through terminator
- Connect additional ~1.6m piece of RG58 coax to the 3rd leg of the T.
- Leave the end of the ~1.6m piece unterminated.
Result: As expected, we get reflection at unterminated end. This results in interference being seen by oscilloscope. Amplitude measured by oscilloscope collapses to near zero (about 200mVp-p in reality) at about 31Mhz. Given prop-speed of \$1.98e8m/s\$ this is at \$\lambda = 6.38m\$, which is a good match for \$\lambda / 4 = 1.63m\$.
At 10Mhz \$\lambda \approx 20m\$ and interference almost perfectly "constructive" resulting in an observed amplitude of ~4Vp-p, very similar to the baseline. (note there is no "doubling" due to constructive interference, see below)
Question
What is the correct relationship for observed amplitude in the interference setup as a function of frequency?
My attempt was to just model sinusoidal addition from here: https://dspguru.com/files/Sum_of_Two_Sinusoids.pdf
gives us:
$$ A \cos(\omega t + \alpha) + B \cos(ωt) = \sqrt{A^2 + B^2 + 2AB \cos(\alpha)} \cos(\omega t + \arctan(\frac{A \sin(\alpha)}{A cos(\alpha) + B})) $$
And if we assume near perfect reflection (we nearly have that), then A and B are equal. Just focusing on the amplitude of resultant we have:
$$ Resultant Amplitude = \sqrt{2 A^2 + 2 A^2 \cos(\alpha)} $$
This does indeed give the rough shape of the frequency response however the scale is wrong. Expression above gives 2A at \$\alpha = 0\$ which is clearly wrong by factor of 2 (no doubling). It correctly shrinks to zero at \$\alpha = \pi\$. The amplitudes at the intermediate frequencies are also too high.
A simple linear scale factor to push the low frequency amplitudes down to the correct, observed value, fails to align the frequencies around 20Mhz.
I suspect this is because we are not modelling the actual network of impedances here, and the reflected wave is not a "second source" (hence no doubling).
There is also the potential issue that the reflected wave may(!) see two 50Ohm loads in parallel, ie 25Ohms and that there will therefore be a secondary reflection back to the open ended stub?
I am ideally looking for a simple electrical equivalent circuit, for example:
Z will be changing from an "open circuit" at low frequencies to a "short circuit" ~ 31Mhz.
So, in summary, what I am looking for is an expression for the signal seen by the oscilloscope across the 50Ohm feed through terminator which incorporates a good model for the changing Z.
