What are the risks involved if one were to stand between two large conducting plates (i.e area where air acts as the dielectric for these plates) and the capacitor is connected to a large voltage power supply in the following cases:
If the high voltage power supply is DC and applied for a long time and someone suddenly enters between the plates, is there any possibility of getting shocked in the transient state?
If the high voltage power supply is AC then what will be the effect at steady state if someone were standing in between the plates?
I thought that since the plates are electrically isolated due to air, if one were to stand in between the plates, they aren't going to get shocked although there is continuous current flowing through it (but it is due to the change in the electric field which causes induced electric current and the electrons of the air don't participate in current flow.)
I'm not sure whether I'm correct or not .
