I'm trying to send some data through UART using DMA. I'm also using DMA to control ADC and DAC. When ADC is enabled and I try to send data I get a HardFault error. The HardFault occurs exactly during execution of HAL_UART_IRQHandler(&huart2) at the line: uint32_t isrflags = READ_REG(huart->Instance->ISR); . When I stop the ADC the problem disappears but I can't understand why?
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart)
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
    if (i<2048)
        FFT_buffer_in[i] = (3.3*analogInput)/4095;
        i++;
    else
        i = 0;
        doFFT();
int main(void)
      uint8_t MSG[] = "yo waddup ";
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_ADC1_Init();
  MX_DAC1_Init();
  MX_TIM2_Init();
  MX_TIM1_Init();
  MX_USART2_UART_Init();
   arm_rfft_fast_init_f32(&fft_handler, 2048);
   HAL_ADC_Start_DMA(&hadc1, &analogInput, 1);
   HAL_DAC_Start_DMA(&hdac1, DAC_CHANNEL_1, (uint32_t*)Wave_LUT, 128, DAC_ALIGN_12B_R);
   HAL_TIM_Base_Start(&htim2);
   HAL_TIM_Base_Start(&htim1);
  while (1)
  //HAL_ADC_Stop(&hadc1); -- only if I uncomment this, the UART_Transmit works
  HAL_UART_Transmit_DMA(&huart2, MSG, sizeof(MSG));
  HAL_UART_IRQHandler(&huart2);
    HAL_Delay(500);
    \$\begingroup\$ You are not supposed to call HAL_UART_IRQHandler. It will be called by the interrupt handler. \$\endgroup\$
    – Codo
    Feb 27, 2021 at 21:06
  • \$\begingroup\$ If I don't call it manually, the HAL_UART_TxCpltCallback never executes - don't know why. Also when I don't call this IRQHandler the UART_Transmit sends data only once instead of sending data every 500ms. \$\endgroup\$
    – blankMCU
    Feb 27, 2021 at 21:29
  • \$\begingroup\$ You do call it directly. It's right there in the code of your question. And if HAL_UART_TxCpltCallback is not called, temporarily remove the DAC and ADC stuff and work on this issue until it's solved. \$\endgroup\$
    – Codo
    Feb 27, 2021 at 22:36
  • \$\begingroup\$ You're supposed to create a UART2_IRQHandler() function which calls HAL_UART_IRQHandler() (or it might be USART2_IRQHandler(), depending on your specific micro which you haven't shared with us). Check your project's assembler startup file (startup_stm_something-or-the-other.s) for the correct function name - it should have all the xxx_IRQHandler function names listed there. \$\endgroup\$
    – brhans
    Feb 28, 2021 at 2:50
    \$\begingroup\$ By far the most likely cause of a hardfault on that like of code is that your huart2 uart 'handle' structure has been accidentally overwritten - in particular the Instance member which is supposed to hold a pointer to the UART's register set. My best guess is that you have not correctly configured the ADC DMA correctly, and the DMA is doing a kind of 'buffer overflow' and writing to that region of memory. Show us the code where you configure the ADC DMA & the buffer (array) you're DMAing into. \$\endgroup\$
    – brhans
    Feb 28, 2021 at 2:54
I've fixed it. It didn't call the USART2_IRQHanlder() because I didn't enable USART global interrupts. That didn't fix the whole problem though. UART Transmit still didn't work properly - it was in BUSY state after sending 1 message. I followed the code and found why - turns out the HAL_Delay(500) affected the memory where the state was stored and that's why the state value was incorrect. Thanks for all your input, it helped me follow the problem to its root.
