I am trying to identify the blown varistor from my fluorescent light tube when I was trying to fix it.
I have never seen a manufacturer marking logo on it with a "W" and a cross in the middle. Not sure what the "P050" means but I think "250" could be the voltage tolerance.
It'll be a great help if somebody knows what the specifications are.
- I found the part for the Dark Red capacitor to replace it.
- The diameter across the varistor is about 7.5mm in diameter.
- The varistor is across the input supply.
- I'm not quite sure for the voltage rating of the ballast probably 220V...? I'm in a European country.
