I tried connecting the one on the left with the 4 pin fan connectors on my computer PSU, but they are not compatible.
  • \$\begingroup\$ Is that by any chance attached to an LED strip? \$\endgroup\$
    – pjc50
    Jan 15, 2013 at 15:07
  • \$\begingroup\$ @pjc50 That would be my guess too - the wire colors are the R/G/B and ground, for typical RGB LED strips I have seen. \$\endgroup\$ Jan 15, 2013 at 15:36
  • \$\begingroup\$ Your fan has +. gnd, pwm and rpm(sense). Are you sure it looks exactly like that, because that is not one of the common fan connectors. \$\endgroup\$
    – Gunnish
    Jan 15, 2013 at 18:37
  • \$\begingroup\$ It is indeed a RGB LED strip. I only tested to see if it was the same connector. \$\endgroup\$
    – user922764
    Jan 15, 2013 at 19:20
The flat prongs make it look exactly like a JST (Japan Solderless Terminal Mfg. Co.) SM connector (Datasheet)
See: http://www.adafruit.com/products/578
  • \$\begingroup\$ I googled "JST SM" to see the connector from a different angle and sure enough, it is the same connector! Thank you very much. \$\endgroup\$
    – user922764
    Jan 15, 2013 at 19:23
