I am using a Microchip MCP2210 USB to SPI converter, however during operation, there is a delay between the sent bytes. Is there a way to remove this ?
You don't say what that delay is, but page 38 of the datasheet (https://ww1.microchip.com/downloads/en/DeviceDoc/22288A.pdf) has settable parameters at offsets 16-19 that may resolve your issues.
A quick scan of the data sheet shows four or five High Byte/Low Byte pairs for registers with the label "Delay Between Subsequent Data Bytes". You should check them all.
\$\begingroup\$ Those bits are already set for no delay. The delay that I am experiencing is that of about 12ms. Thanks \$\endgroup\$ – Chris Mar 4 at 15:00
\$\begingroup\$ @Chris how big a packet have you defined? \$\endgroup\$ – Scott Seidman Mar 4 at 15:29
1\$\begingroup\$ There are a few registers with the same name. Keep searching. Also, have you actually read the settings? Experience tells me that there's sometimes a difference between believing your procedure to set the registers worked, and knowing they've worked! \$\endgroup\$ – Scott Seidman Mar 4 at 16:13
