I have a problem with the circuit below:
I'm using the op-amp as differential amplifier for low-side current sensing with gain of 100. All resistors are 0.1% and the load is just a variable resistor for testing the circuit.
The problem is no matter what load I have and how much current is going through the sense resistor the output of the op-amp is around 23 - 24 volts. I tried switching all of the components checked all the connections and even rebuilt the circuit on a bread board with no avail. I feel like there is something obvious that I'm missing.
I have the same circuit in simulator and it works just fine.
Update: As I mentioned I did miss something obvious and didn't check the datasheet fully.
