I got this arduino shield with four 7 segment display what I'm trying to make work with STM32 nucleo. The displays are driven with two 74HC595 shift registers.
I wrote the following code to control it, but somehow it doesn't work, always shows the same pattern whatever I modify in the array.
int digits[16] = {1,1,1,1,1,0,1,0,1,0,1,1,0,1,1,0};
while (1) {
    HAL_GPIO_WritePin(STCP_GPIO_Port, STCP_Pin, GPIO_PIN_RESET);
    for(int i=0;i>=15;i--) {
        HAL_GPIO_WritePin(SHCP_GPIO_Port, SHCP_Pin, GPIO_PIN_RESET);
        if(digits[i]==1) {
            HAL_GPIO_WritePin(DS_GPIO_Port, DS_Pin, GPIO_PIN_SET);
        }else {
            HAL_GPIO_WritePin(DS_GPIO_Port, DS_Pin, GPIO_PIN_RESET);
        HAL_GPIO_WritePin(SHCP_GPIO_Port, SHCP_Pin, GPIO_PIN_SET);
    HAL_GPIO_WritePin(STCP_GPIO_Port, STCP_Pin, GPIO_PIN_SET);
SHCP: Shift register clock
STCP: Storage register Clock
DS: Data
What could be the problem?
Your for loop has an error. It would try to count backwards from 0 until it is larger than 14. My rough estimate is that it takes about 2^31 loops until the count reaches largest negative number and rolls back to largest positive number before the for loop exits.
  • \$\begingroup\$ Indeed, that was the solution. Thank you! \$\endgroup\$
    – LocalHero
    Mar 7, 2021 at 21:08
