I have looked over this tutorial (Tutorial - Using Modelsim for Simulation, for Beginners. ) how to add waves and write test benches for VHDL module
I looked over some answers as well like this one to find out but I could not use it.
Quartus, Modelsim, VHDL - Viewing Internal Signals
Now, if I want to add some internal signals and view them, how can I do since I am using the vhdl code as components in the testbench?
and to clarify it well, here is the code of the module:
 library ieee;
 use ieee.std_logic_1164.all;
 entity and_gate is
 port (
 input_1    : in  std_logic;
  input_2    : in  std_logic;
 and_result : out std_logic
 end and_gate;
 architecture rtl of and_gate is
 signal and_gate : std_logic;
 signal not_and  : std_logic;
 begin
 and_gate   <= input_1 or input_2;
 and_result <= and_gate;
 not_and    <= not and_gate;
 end rtl;
and here is the code of testbench library ieee; use ieee.std_logic_1164.all;
 entity and_gate_tb is
 end and_gate_tb;
 architecture behave of and_gate_tb is
 signal r_SIG1   : std_logic := '0';
 signal r_SIG2   : std_logic := '0';
 signal w_RESULT : std_logic;
 component and_gate is
 port (
  and_result : out std_logic);
 end component and_gate;
 begin
 and_gate_INST : and_gate
 port map (
  input_1    => r_SIG1,
  input_2    => r_SIG2,
  and_result => w_RESULT
process is
begin
r_SIG1 <= '0';
r_SIG2 <= '0';
wait for 10 ns;
r_SIG1 <= '0';
r_SIG2 <= '1';
wait for 10 ns;
r_SIG1 <= '1';
r_SIG2 <= '0';
wait for 10 ns;
r_SIG1 <= '1';
r_SIG2 <= '1';
wait for 10 ns;
end process;
end behave;
and here are my signals are all went to red eventhou I added their waves: enter image description here
    \$\begingroup\$ What exactly you didn't understand from Quartus, Modelsim, VHDL - Viewing Internal Signals ? It clearly shows how to add internal signals. \$\endgroup\$
    – maximus
    Mar 8, 2021 at 20:37
  • \$\begingroup\$ I updated my question. I did not understand how to add waves from vhdl code even though I added them as you see in the updated question \$\endgroup\$
    – Yaakov
    Mar 8, 2021 at 21:22
    \$\begingroup\$ @Yaakov I wasn't able to reproduce your problem. The simulation gives me proper results and shows all internal signals. I had to complete the code of the testbench though: add libraries, entity and architecture declarations. I am not sure what the problem may be. Btw, you have a funny name for OR logic. \$\endgroup\$
    – megasplash
    Mar 9, 2021 at 6:46
  • \$\begingroup\$ The code was mainly made for AND logic and I wanted just to check if I change the code,the waveform changes too. What can go wrong in my testbench code then? \$\endgroup\$
    – Yaakov
    Mar 9, 2021 at 6:55
    \$\begingroup\$ @Yaakov I have posted an answer, hope it helps. Let me know, if you need to see my testbench code. \$\endgroup\$
    – megasplash
    Mar 9, 2021 at 6:57
There is a chance, that you didn't compile all the updates in your code.
Here is how it should look:
Modelsim screenshot
Basically, you can add any signal in your project to a waveform to simulate. After creating Simulation Configuration you double click on it in a Project tab, which should get you to the sim tab. You will see the hierarchy of your project there. By clicking on the name of the entity under test, you will be able to see its internal signals in the Objects tab. Then you just right click the desired signals and choose Add Wave.
  • \$\begingroup\$ Perfect It is showing now the behaviour of internal signal. a side question, in my modelSim window I do not have the same view as you where I can see the project tab, how can I bring it back? \$\endgroup\$
    – Yaakov
    Mar 9, 2021 at 7:22
    \$\begingroup\$ I'm glad, that it helped. There is a View menu, where you can select Project by clicking or pressing x. \$\endgroup\$
    – megasplash
    Mar 9, 2021 at 7:25
  • \$\begingroup\$ Would you mind adding / including the test-bench code to your answer? It could be rather helpful, I think. \$\endgroup\$
    – Henke
    Apr 1, 2021 at 11:27
    \$\begingroup\$ @Henke Sure. Any working example is always useful, I guess. \$\endgroup\$
    – megasplash
    Apr 1, 2021 at 12:03
  • \$\begingroup\$ Thanks! Not sure when I will have the time to look into the details, but very much appreciated that you added the code! 👍 \$\endgroup\$
    – Henke
    Apr 1, 2021 at 12:41
