it's known, and there are some devices that exploit this phenomenon (see the references if you want), that if an electromagnetic source (antenna) is placed between two different dielectric layers, the waves will prefer one over the other according to the frequency.
Here you see an example from one my simulation.
Half-wavelength dipole antenna: it radiates equally in all directions of ϑ = 90° plane.
Now I put two different dielectrics (yellow = eps 20, blue = eps 2). Note that the permittivity is assumed to be constant on frequency (non-dispersive medium).
Conclusion: at such a frequency (3GHz, in which the dipole resonates), the waves prefer going towards the low permittivity medium (greater amplitude).
At other frequency the situation changes and the role of the two dielectrics may be reversed.
What I'm looking for is not a math explanation of that, but just an intuitive and physical view. If the antenna were a voltage source and the two materials were two parallel impedances, I'd say that electrons (current) will be higher in the easiest path (lowest impedance). But in this case there are not charge flowing, but just a wave. What causes physically a wave to prefer a material? Why should its electric and magnetic field be higher in one of them and why does it depend on frequency?
The electric permittivity is assumed to be constant on frequency, and the magnetic permeability is assumed to be 1. So, we can't say that the frequency - dependence is due to the material electric/magnetic polarization variation as frequency changes.
Example at 2GHz Now the waves prefer the yellow dielectric. enter image description here
References: here (page 5) and here (page 3), two antennas are showed and they have both a substrate (like ordinary planar antennas) and a superstrate. The last one is used to send more power on the upper direction instead of to the lower one (where there is the substrate).
  • \$\begingroup\$ "At other frequency the situation changes and the role of the two dielectrics may be reversed." - evidence? \$\endgroup\$ Mar 9, 2021 at 19:30
  • \$\begingroup\$ you might get better answers from the physics stack exchange imho \$\endgroup\$
    – vicatcu
    Mar 9, 2021 at 19:31
  • \$\begingroup\$ @Bruce Abbott You are right. I've added now the picture of the situation at another frequency. \$\endgroup\$
    – Kinka-Byo
    Mar 9, 2021 at 19:50
    \$\begingroup\$ @vicatcu Yeah, this topic has many physics questions. But each time I asked similar topics in physics, they told me it's an engineering topic :(. And it's partially true, since this phenomenon is exploited in many antenna designs. It's a topic in between \$\endgroup\$
    – Kinka-Byo
    Mar 9, 2021 at 20:20
Dielectric wall reflects waves. Reflection is complex because every time the wave meets a border of medium it gets partially reflected. Depending on wavelength, plate thicknesses, their materials and placements it's well possible that the radiation to one direction is stronger than to the other direction. The radiation is strongest to the direction where most of the waves (incident, reflected, reflected multiple times) travel with least phase cancellation.
  • \$\begingroup\$ Thank you for your answer. Do you mean something like a zig zag reflection between the two plates? \$\endgroup\$
    – Kinka-Byo
    Mar 9, 2021 at 20:46
    \$\begingroup\$ Yes. But that's not so simple if one plans to calculate something. There's also the reactive near field of the antenna which is disturbed if the plates are near enough. I guess in that case only simulation or experiments with a real antenna in echo free room and proper measurement tools can give usefully accurate results. \$\endgroup\$
    – user136077
    Mar 9, 2021 at 20:53
