Recently I began a project involving some active current limiting using a MOSFET and an Op Amp. It is part of a larger overall circuit involving other Amplifiers.
I would like to perform a block-diagram-style analysis on my circuit in order to investigate loop gain and stability. However, I was stuck when it came time for me to analyze the MOSFET's transconductance behavior. The simplified example below illustrates my problem:
The circled block in the above diagram is what I'm trying to unpack. As stated in the diagram, since this is part of a stability analysis, I really only need the RC pole location and the transconductance.
Is there a way to model any MOSFET Trans conductance amplifier as a single-pole Transfer Function?
Furthermore:
How would I go about extracting the necessary parameters from I-V curves within the MOSFET datasheet?
EDIT: More details on what I'm looking for: I understand my dummy example has stability concerns due to the OA's dominant pole and the additional pole from the series R and the MOSFET's Ciss. Of course this leads to instability in some scenarios.
I want to know how to pull out the MOSFET's behavior into its own "block" as seen in the block diagram in my post. I assume its "block" looks something like gm*{Something}/(1+s{Some_Tau}). I'm wondering how to extract the "something" and "some_tau" from datasheets within some reasonable tolerance. I know Ciss varies somewhat, but I'm fine with some reasonable accuracy.
