I've been may asking the really easy question.
The circuit which was made of the AC source and the coil exists.
\$L:=\$self inductance of the coil.
\$v(t):=v_0*\sin(\omega t)\$ (The voltage between the terminals of the coil.)
\$i(t):=?\$ (The current which flows through the coil.)
We want to know the current which flows through the coil.
\$v_L(t):=-L\frac{di}{dt}\$ (The induced EMF which arises at the coil)
\$-v_0*\sin(\omega t)+L\frac{di}{dt}=0\$ (kirchhoff's voltage law)
\$L\frac{di}{dt}=v_0*\sin(\omega t)\$
\$\frac{di}{dt}=\frac{v_0*\sin(\omega t)}{L}\$
\$\int1\frac{di}{dt} \frac{dt}{1}=\int_{}^{}\frac{v_0*\sin(\omega t)}{L}\frac{dt}{1}\$
\$\int1*di=\frac{v_0}{L}\int_{}^{}\sin(\omega t)dt\$
\$i(t)=\frac{v_0}{L}\frac{(-\cos(\omega t))}{\omega}+C\$ (\$C\$ represents the constant of integration)
\$=\frac{-v_0}{\omega L}\sin(\frac{\pi}{2}-\omega t)+C\$
\$=\frac{v_0}{\omega L}\sin(\omega t -\frac{\pi}{2})+C\$
The below statement is the problem for me.
The textbook substituted \$0\$ to \$C\$ and states that the dc component is assumed as \$0\$ .
Currently I'm unable to get why the value of the constant of integration is zero and the meaning of dc component in this circuit.
Can anyone tell me some idea(s) or the website(s) which describe(s) of it?
