I would like to control the two switches in the picture at the same time.
So for example when the left switch is in position 1 the second switch is also in position 1.
Is a 2-pole rotary switch what I'm looking for?
Also sorry if the way I used the schematics for the switches doesn't make since. Basically I want the switches to select between different resistor branches.
yes
andyes
