This is the default title block. As you can see it already has a date filled in. But being european I don't like the mm-dd-yyy order. Is there a way to change that?
1\$\begingroup\$ I think the only possible way to do this is make your own template, there you can adapt the data field. \$\endgroup\$– J. JolyMar 10, 2021 at 11:34
\$\begingroup\$ I chose this way. And I see that in the new custom title block the date is formatted the way I want it. So probably according to regional settings from the OS. \$\endgroup\$– HneelMar 10, 2021 at 14:33
\$\begingroup\$ It doesn't matter whether it's the original or a bespoke template, as soon as you edit the sch file the date will reformat to the current regional setting. \$\endgroup\$– Spehro PefhanyMar 10, 2021 at 14:34
1 Answer
There is no way from Altium Designer. Altium just uses the Regional settings in Windows to determine how to display =CurrentDate in the title block. So, change it in Windows:
Start->Control Panel->Clock, Language and Region->Change the date, time, or number format
You may have to type the desired format in rather than just selecting from the drop-down box.
