I am using the DC-DC boost converter MT3608 for a project where my input ranges around 1 V. Is there a way to modify the circuit so that the boost converter can operate at voltages less than its minimum rated input voltage i.e 2 V? If yes, what exact modifications are required in the boost converter or the circuit around it?
4\$\begingroup\$ Not worth it. Choose a different boost converter. Linear have some excellent for the purpose which starts at <1 V. \$\endgroup\$– winnyMar 10, 2021 at 19:12
\$\begingroup\$ the ones i require are not available in my country. Could you maybe suggest alternatives for making my own that boost voltages from about 0.5-0.9 to about 3 V \$\endgroup\$– Atharva MeteMar 10, 2021 at 19:17
\$\begingroup\$ Mouser, DigiKey and Farnell ships all over the world, so it’s available to you all right. \$\endgroup\$– winnyMar 10, 2021 at 19:21
\$\begingroup\$ international shipping is a pain in our country atm. I also have a time crunch on this. Is there some alternative that you know of? \$\endgroup\$– Atharva MeteMar 10, 2021 at 19:29
\$\begingroup\$ You haven't stated current. Choose a different boost converter. \$\endgroup\$– StainlessSteelRatMar 10, 2021 at 19:41
1 Answer
No, according to the datasheet, the MT3608 does not work with voltages below 2V.
\$\begingroup\$ There is also a lockout of 1.98V. So 2V minimum. \$\endgroup\$ Mar 10, 2021 at 19:06
\$\begingroup\$ Thanks for the quick reply. Can we build an inexpensive circuit around it to step it up to 2V somehow. something like a joule's thief (this was very inefficient in my case) \$\endgroup\$ Mar 10, 2021 at 19:09
