In one my assignment questions, I need to find voltage across a capacitor. This is the diagram given:
And the conditions given are:
1- Switches A and B are in perfect sync, and when A opens, B closes and vice versa. Also their positions change every 30 ms.
2- Initially switch A is open. Assume steady state is achieved
And the question is to find voltage across capacitor at time instances:
  1. t=0+ and 0-
  2. t=50ms+ and 50ms-
  3. 60 ms
So considering the open switch and steady state condition of capacitor (acts as open circuit). I reduced the circuit to this:
The voltage across capacitor will be same as voltage across the 7 ohm resistor.
Applying current division and also taking into consideration the 3A current through the 7 ohm resistor, I got voltage across the resistor as approx 23.205 Volts.
Also as this is a forced response, the voltage across capacitor will be Vc = Vo - Voe^(-t/RC)
So at t=0+ and 0-, i.e steady state Vc = Vo = 23.205 volts.
But I am unable solve for the other parts i.e 50ms and 60ms as I am not sure how to take into account the position change in both the switches. How do I go about it ?
  • \$\begingroup\$ think about this ... when does the current from the 10 A source flow on the left side of switch A? \$\endgroup\$
    – jsotola
    Mar 12, 2021 at 7:28
  • \$\begingroup\$ +1 for identifying this as an assignment and showing some work. \$\endgroup\$ Mar 12, 2021 at 15:03
