module test1(input logic A,B,C,D);
 output reg Y;
 always@(A,B,C,D) begin
  case({A,B,C,D})
    4'b0011: Y<=1;
    4'b0111: Y<=1;
    4'b1100: Y<=1;
    4'b1101: Y<=1;
    4'b1111: Y<=1;
    4'b1110: Y<=1;
    4'b1010: Y<=1;
    default: Y<=0;
  endcase
 end
endmodule
The following code is showing the following error:
------- Error Output --------------
test_bench.v:12: error: port ``y'' is not a port of dut.
1 error(s) during elaboration.
Could I know what is the issue?
    \$\begingroup\$ well, y is not a port of dut tells you what's wrong. Your problem is in test_bench.v in line 12. We don't know your line numbering, so you're the one who needs to help yourself. \$\endgroup\$ Mar 12 at 7:32
According to the section "12.3.1 Port definition" in one of the revisions of the Verilog standard, a module includes [ list_of_port_declarations ] ; with the following syntax:
list_of_port_declarations ::=
      ( port_declaration { , port_declaration } )
port_declaration ::=
      {attribute_instance} inout_declaration
     | {attribute_instance} input_declaration
     | {attribute_instance} output_declaration
That means that for your design the ports declaration should be the following:
module test1
    input logic A,B,C,D,
    output reg Y
Some comments on the design:
  • There is no reason to use reg anymore. Use logic instead.
  • Use always_comb instead of always@ for combinational logic. The sensistivity list is automatically generated.
  • Use blocking assignments for combinational logic.
module test1
    output logic Y
always_comb begin
 case({A,B,C,D})
    4'b0011: Y=1;
    4'b0111: Y=1;
    4'b1100: Y=1;
    4'b1101: Y=1;
    4'b1111: Y=1;
    4'b1110: Y=1;
    4'b1010: Y=1;
    default: Y=0;
  endcase
 end
endmodule
