I know that a silicon diode with forward bias drops 0.7V, and I also know the two resistors should have the same voltage drop because they have the same resistance and same current (because the branch with the opposite diodes in series should have a current of almost 0). Knowing that I can calculate that the resistors drop 4.3V and the 2 forward bias diodes drop 0.7V, and I expected the other diodes to drop 0V. But simulating this circuit on CircuitLab gives the following voltage drops:
I don't understand why the opposite diodes in series drop 2.5V each. If anything I would think the forward biased diode should drop 0.7V and the reverse biased diode should drop the remaining 4.3V, but that doesn't seem to be the case. Why is this?
These are "ideal diodes" on CircuitLab but I assume they will behave the same. Is this a correct assumption to make? If not, what would change if they were silicon diodes in real life?
