I was reading through MOSFETS, and the most prominent parameter is drain source "on" resistance. I am unable to figure out what it is. suppose for a given gate source voltage V_GS we have applied a drain-source voltage which brings saturation to the MOSFET, at this point still the MOSFET approximately works as a resistor? if not what is the resistance between source-drain now? is source drain resistance is only applicable for the linear region only? or is it for any region?
    \$\begingroup\$ When MOSFET is working in saturation he will be acting as a voltage-controlled current source (we use this region in CS amplifier for example ). But, when using MOSFET as a switch (triode region Vds < (Vgs - Vth) ) then we can use R_ds(on) resistance to find the Vds voltage and power dissipated by a MOSFET. \$\endgroup\$
    – G36
    Mar 13, 2021 at 12:22
Here's a MOSFET characteristic from wiki: -
Note where the saturation region is and now, if I focus on the linear region (not the saturation region), I can show various values of on-resistance in orange: -
Basically, on-resistance is the slope of each blue curve close to the origin of the above graph.
It's not perfect but, providing your expectation of "linearity" isn't too high, then, in the linear region, it behaves like a voltage controlled variable resistor (where the slope of each orange line above is measured in ohms).
