I want to set up an experiment exactly as given in this data sheet for the T/R switch that I recently bought (the MD0101):
Every pulser receiver circuit that I’ve found neglects to address what happens during the “receive” portion of the event, i.e., if you’re using a function generator that just pulls the output to ground after sending out a pulse train, how are you supposed to be able to sense any movement in the piezo transducer if both of its plates are grounded?
The only way this circuit would work is if the function generator immediately disconnected its channel after sending out the pulse train, correct?
